D19 Roosa mater injection pump leaking
VC/TX
any body know how remove the throttle & kill lever shaft on the roosa mater injection pump.
I would like to replace the o ring on mine, it"s starting to leak a little diesel around the shaft on the pump on my D19.
need to know how to remove the shaft,any help would be appreciated
CLEAN the darned thing up. Remove the pump cover.
Remove a goofy little clip, allowing the throttle shaft to be withdrawn from the IP.
Replace the "O" rings on the throttle shaft, slather them up with a little Vaseline, and put the shaft and clip back in place, while keeping all the associated parts in place.
Put the pump cover back on.
(One of those things that's a lot easier to DO than to write about!)
