D3B that won't move
LGoff
I am having trouble with this machine just stopping. It ceases to move. I originally noticed that in the morning, when first cranked, I could put it in gear and it would not move. I could try again or maybe rev engine more and it would go fine and be fine the rest of day. Now, i can be using it and it just stops. I can maybe let it set a while and come back, it may do OK for a little bit, then stop again. I was told it could be a filter/strainer on the transmission? Any ideas?
yes--the filter is on top of the tranny, under your seat, change filter and cut open the old one to check for particles, also there is a strainer screen at the bottom of the tranny at the drain plug,--but you will have to dump all the tranny oil to check the screen---does this happen in forward and reverse?
There is a plastic screened Orifice in the trans valve. It controls pressure modulation when you shift. Sounds like it might be clogged up or broken and blocking it's self up. Change the filter and cut it open, look for dirt and metal in it. Come on back with what you find. Then I will tell you more.
Later Bob
mine is the 3F/1R and i did not see a filter. I will change oil and check everything and see what I can find.
Disreguard what I said, it's for the 3F3R trans. Clean the screen, under a large cover on the RH back of trans. If that doesn't fix things reseal tubes to pump mounted inside the front of trans.
Later Bob
I've drained the oil and found the screen. I'm going to buy another screen and put in it, just to be sure. It did have some metal shavings in it, but I would not say a bad amount. I'm not convinced this will fix it. It had got to the point of when I crank it up cold, it would not move but bouncing the blade up and down to the ground, would kind of kick start it to moving.
Just wash the screen and it will be okay. I think you should wash the top plate off clean. Take it off and remove the valve and pump. Replace all of the o rings. I think the pump is sucking air through bad seals on tube to suction screen.
Later Bob
