d4 crawler track wont spin
clmoody32
got a 1953 cat d4 thats not spinning passenger track, was working great then all of a sudden (I think it happend when i was spinning on rocks against a stump) lost power to track. any ideas?
if you still have resistance on the right steering lever when you pull it back, and if when you push the right brake without pulling the steering lever back and here the engine lugging down, i would look at the final drive--drain the oil in it and look for particles
sounds good I have resistance on that steering lever. and when I push the brake down without pulling the steering lever it bogs the motor down and turns. but i hear chatter or grinding when I do that, so ill start with draining the oil and look for particles. also when i am moving along and pull the left steering lever without pushing the brake the crawler keeps moving forward. when i pull the right steering lever without the brake it stops the crawler thanks
Your probleme should be a final drive top pinion
and you need to remove the stering cluchs for replaced the pinion.
If you pull the right clutch and the crawler stops, and stepping on the right brake bogs the engine down then you have a problem in the left side. When a clutch slips it may make a grinding sound. Simply means it is slipping. You still need to pull the finals if adjustineg the clutches doesn't fix it.
original possum--i always thought that the brake band and drum are on the final drive section of the steering clutch--so if the engine bogs down then the resistance torque is transmitted back thru the steering clutchs thru the transmission to the engine?
After reading about your pulling the left lever and right lever and what happened I think the left clutch is slipping badly.
Later Bob
