D4 (HT-4) Fluid Capacities
Anonymous-0
I've recently acquired a D4 (Serial# 7U23904) with a Trackson loader (HT-4). Does anyone have the fluid capacities from the Operators Manual that you could post or email a scanned copy? I'm planning to get a manual soon, but would like to change all the fluids now. Also, does anyone know if you can remove the fuel filters without removing the hydraulic tank on the HT-4? Looks like a tight fit! Thanks, Nate.
hello Nate88,info need ,not sure about the filters,
crank case 15 quarts
trans 18 quarts
finals each 7 quarts
hyd 16 gallons
bruce oz
Nate88,
Access to the entire upper portion of the engine is gained if certain steps are followed: 1) remove the exhaust stack, 2) remove the guard over the surge tank (four cap screws), 3) remove the three cap screws holding the surge tank to the frame. The tank, although still being connected to the hose, may be moved to the left sufficiently to remove the valve cover , change fuel filters or accomplish other minor mechanical work.
Noting if one had two elbows on each arm they would be a lot easer to work on. LOL….hope this helps and good luck.
Kelly
