Dairy farmer in WI
Anonymous-0
well me and the neighbor got a new project to work on together. It's a Farmall M with the M&W 9 speed in it but needs lots of parts. besides that the engine is stuck. anyone have a sure-fire way to get it unstuck? we thought about plugging hydralic hoses into the spark plug holes and hooking it up to a tractor. the oil HAS to go somewhere and hopefully it will push the pistons to get it unstuck. any help or suggestions would be GREATLY appreciated.
thanks
i will post pictures of it later
DF in WI
I've heard of using grease to push them out, and I think it'd be a little safer than using the remotes on another tractor. It's a little slower but more controled.
Donovan from Wisconsin
grease is a good way i've heard, but if i was gonna unstick one, i'd pull the head and pour some kerosene mixed with trans fluid in the cylinders and set it on fire. the heat will expand the cylinders just enough to knock the pistons out. it might take a few burning cycles, but i hear it works pretty good. good luck!
slowride>
