David Bradley Super 300
cacknacker
Hello-i have a super 300 David Bradley walk behind that I used with the front plow to plow snow last year.Because it goes pretty fast-does anyone know of a way to slow it down a notch so I can keep up with it? Thanks.
You can put a smaller pulley on the engine.They also made a attachment using a second shaft and 2 belts. it was used with the tiller attachment.It is hard to find one, but you might blacksmith your own.
I have had a couple of D B walk behinds and that engine pully is as small as can be had, about an inch and a half. No way to get it any smaller. One I had Uncle had later and tried to slow it down using a big pully of an AC combine but did not work very well. Throtal down and no power to pull itself. They were a run behind machine. To be able to do any work you would have had to have that tiller gearing.
Thanks everyone for your suggestions-we are well aware of the throttle it down DUH-comment.The best bet is to try and make something.
