db nose job
HP 28-50
Have 4600 DB. The top cowl of the nose cone has that common DB wrinkle. I believe I've located one about 200 miles away. It comes off a brown belly 990. The grille on a 990 looks to be taller than its little brother but is the top of the nose the same. I don't want to drive there for nothing.
If you find a 880 DB it will be the same but do not think the 990 is the same since the part number for the grille is different on the 990 where are you located. jc
