Stoneman44
Morning All,
I'm going to do my first servicing on the new tractor this weekend and had a few questions.
In reading the service manual, the recommended ENGINE oil is a Multi-purpose 20W/30 or 20W/40. My local RK store has 15W/40, will this suffice?
The "Approved Lubricants-Except U.K and Ireland" recommends the same oil for the Transmission & Hydraulic System. Still good to use the 15W/40?
For the Power Steering it recommends "Hydraulic mineral oil of SAE 10W viscosity (Not brake fluid). What the heck is this? Where can I find it and is there an alternative?
For the Final Drives, King Pin and Front Trunnion it recommends an SAE 90 @ < 20 degrees F, and SAE 140 @ > 20 degrees F. Is an SAE 85-140 OK to use for these applications?
Should I use Conventional or Synthetic oils?
Would anyone recommend one oil over another? I run Valvoline in all my vehicles and thought I would use Valvoline Premium Blue Heavy Duty Diesel for the tractor.
Will any multi-purpose grease work for lubrication?
Thanks for your help!
