Was going to ask the same here soon. Years past they ran all no cut tire classes first. Then ran all top cut classes and then full cuts last. Not leaving the house as early this year if it is the same.
From what I understood at the meeting it will be the same as last year. All uncuts then topcuts and finish with the full cuts
Need to somehow find out from someone that knows for sure. Been there the past two years and ran as I said earlier. I didn't start pulling till noon or so last year and just want to get there closer to my classes.
(quoted from post at 20:23:18 02/20/13) DCTPA what will the class order be for the Eaton pull
I just talked to Loyd about this and he said we are going to pull all the non-cuts first, light to heavy. Then we are going to alternate the top-cuts and full-cuts, light to heavy.
So it will be 3500, 4500, 5500, 6500 & 7500 non-cut.
Then 3500 top-cuts, 4500 full-cuts and so on.
The 0rder for Eaton pull will be all uncut. Then start with 4500 full cut then 3500 top cut and back forth from there Any questions give me a call at 937-533-2047 thanks and see you there Dwight
