Dear barney
SVcummins
The longer I look, the more I'm squinting.
It's too bad that smart phones can take such wonderful photos, yet suck so badly at capturing screenshots.
Pintle hitch trailer hooked to a regular ball with a muffler clamp around the ball with the ratchet and socket still attached . Hitch clamped on top of all that with a scissor Jack yellow toe strap Also clamped with the scissor Jack for safety
On my 27" monitor the picture is 1-1/4"x2". When I zoom in, it gets grainy.
Could not tell what was going on without your detailed description, which brings up other questions.
So yeah, it's the picture not the "compuker."
I have a 19 inch chrome book. It's like using a smartphone. I can zoom in by touching
the screen to make it full screen, good pic.
My lap-top is 17 inches, so when I am reading, I just hold the control button and tap the + key two or three times to enlarge the print. Same thing works for photos--- very clear.
May not be as bad as it seems, it is a truck and there is a load control hitch at the bottom. The contraption is there to hold the pintle ring over the ball on the lower hitch. Place where I worked used to haul the portable compressors with a pintle ring. They had two plates that bolted to the ring ( three bolts spaced inside the ring), lower plate had a ball coupler welded on the bottom. Worked ok as long as the bolts were really tight. They hauled the compressors behind a building rig which was a 1 ton box truck, no way to see the compressor. A crew got to a job no compressor. We found it with the tongue stuck in a tree south of Perry.
I enlarged the picture to fill my 27" monitor. Still could not see what was going on. I could see the shank on top and the scissor jack but beyond that it's just a fuzzy mass of rust.
Comedian George Carlin said,,just think how stupid the average person is and then realize half the people are stupider then that.
