Dennys stroker kit
Anonymous-0
Has anyone bought one of dennys carb shops 350or 392 cubic inch stroker kits. if so how are thy holding up and do they really show the horsepower they say they do.
Dont know about the stroker kits, but the general consensus around here, as you will soon see, is Denny's sucks. Its mostly about the customer service, or the lack there of!!! Good luck either way!
You may want to check past messages and replies on this forum along with other forums about dealing with Denny's carb shop before you spend any money there. Good luck !
All I can say for certain is that the cranks are made by a reputible place in Indiana. If you have trouble it won't be with the crank. As for the as for Denny.....well ...buyer beware
The cranks are made by HAPCO Rebuilders in Terra Haute. IN. Just contact them and get the same crank without a markup. You will need a crank core for them to stroke. You can easily put together the rest of the kit pieces yourself much cheaper.
I have had bad parts from these people. With the amount of people on here that has had bad dealings with the company I don't see how they stay in business.
the one I have seen looked like it was ground with a disk grinder finish was poor with pits also.
Probably WAS ground with a disk grinder..have never seen one with porosity, though and I have seen probably 50 of their cranks.
