Diesel Air Volume ?
M-MAN
Location
Bostic, NC
Is there a difference in air volume required on a diesel and a gas burner when both have the same cubic inches? I don't see how there can be since the air draw comes from the piston going down on the intake stroke and compression shoulden't be a factor, but a friend of mine swears a diesel pulls in more air.
The reason I'm asking is I've been thinking about converting my Ford 800 diesel(172) to a paper filter system. The 2.8 GM's use a roughly 4x4 filter that I think would work in a similar sized airbox as the old oil bath that's rusted away. I realize the filter would have to be blown out regularly but all I do with the Ford is gardening and a little blade work so I'm not worried too much about that.
What do you guy's think?
A diesel will pump much more air through it than a spark ignition engine. The reason is that the diesel has no throttle plate to restrict the air entering the engine. A diesel (compression ignition) engine does not have to have fuel mixed evenly with air to ignite. As fuel is sprayed into the hot air in the cylinder it ignites as it leaves the nozzle tip and the flame lasts as long as there is fuel to burn.
A gasoline engine depends on the spark plug to provide a spark to ignite the air/fuel mixture. If the mixture is too lean or too rich it will not ignite. Like the diesel the amount of fuel delivered needs to match what is needed to create the power demand. If the gasoline engine were to operate without a throttle plate to limit the air allowed the mixture at less than full load would be too lean and misfires or no firing would occur.
The throttle plates reduces the atmospheric pressure in the intake manifold so less air is pushed into the cylinder when compared to the diesel.
Yeah,
'Bout 4 times as much. That's why ya gotta be so darned careful with the diesel air cleaner.
With all that air goin' thru 'er, and it's need for very high compression to operate, any contaminates will just ruin a diesel engine in very short order.
Allan
I'm not disputing what the others are saying but your tractor engine will run about half as fast as the car engine, I dont think you will have a problem.
For a given displacement, and at full power, a non-turbo diesel should pump the same amount of air as a gasoline engine, assuming they are running the same RPM. But at less than full power, as Owen states, the throttle plate comes into play, so diesels thrive on a surplus of air, that is what gives them good economy at part-load.
That said, air filters are applied based on more than engine size. The environment can be worse for a tractor than an over-the-road vehicle.
I don't think you are wrong to try it; I would put an air filter restriction indicator on it and you should be OK. Dodge pickups with the Cummins diesels had a little indicator that told you when to change the filter. Get one from a salvage yard.
A diesel engine and a gasoline engine AT FULL THROTTLE will pump roughly the same air at the same RPM. Displacement is displacement: the volume displaced by the engine as it goes through its cycle. But gasoline engines rarely operate at wide open throttle, so for the most part they don't need as much air. Valve timing, induction and exhaust design and other factors affect the amount of air that an engine requires, but mostly a diesel uses more air because (in most cases) diesel engines have no throttle plate.
172 cubic inches of displacement in a diesel engine is the same as 172 cubic inches of displacement in a gasoline engine. Go have a look at some of the newer, compact diesel engined tractors with similar horsepower and cubic inch displacement as what your Ford has and see what size they use for an air intake filter.
To shed a little more light on the subject, a turbo-charged engine of any given displacement will require a larger air filter than the same displacement engine without a turbo-charger, simply because the turbo will pack more air into the engine, making that engine THINK it is a much larger engine.
Agree the diesel will pump more air. Assuming that the diesel intake system is well designed and runs near 0 manifold vacuum.
The average gasoline carb's throttle plate / shaft / venturi will produce 2-4 inches of manifold vacuum at wide open throttle.
This is necessary so the carb can "suck" fuel from the fuel bowl, through the main jet and venturi nozzle, to mix fuel and air.
I'll second about care of air cleaner and intake restriction indicator. The Caterpillar manual for my truck says DO NOT open air filter unless restriction indicator says it is time. I just checked the indicator on my Ford 6.0 last night, and at four years and 55,000 miles it shows virtually no restriction.
Cubic inch wise one will use just as much air as the other. That said the construction of each engine and the efficiency of the intake setup will also be a determining factor as to how much air is actually drawn in and available for use at any given RPM. My suggestion would be to give the folks at Donaldson a call as they are the true filter experts. They should be able to give you the filter requirements for whatever you may need based on the needed CFM as having too little filter area can cause problems beyond just the filter clogging prematurely.
Donaldson
I used to have a chart from Donaldson that showed how CFM's common engines used. They would be the ones to talk to. I would think a higher compression engine would use a little more air? Dave
(quoted from post at 15:44:11 07/27/10) I used to have a chart from Donaldson that showed how CFM's common engines used. They would be the ones to talk to. I would think a higher compression engine would use a little more air? Dave
Compression ratio will not affect air consumption. An engine is just an air pump. Displacement is what determines how much air can pass through it.
Just remember even tho the gas and diesel are of the same cubic inch, the diesel takes a full gulp of air per intake stroke while the gas only gets a full gulp at wide open throttle. Therefore the diesel needs more filter area or they would plug much more rapidly.
At max flow, there is no difference between the gas engine and the diesel. If there is no turbo, and the bore and stroke match, and the RPMs are the same, so is the air draw. It's based on engine speed and volumetric-efficiency. Most older NA diesels and gas engines are 60% efficient. So, calculate your bore and stroke along with RPMs to figure how much physical volume is moved -and then take 60% of that and it is your air-flow.
As already mentioned, most diesels run wide open air intakes (but not ALL). I have several IH diesels with air-throttle plates. This does not mean, however, that they take in much more air then gassers. This only happens at certain RPMs and throttle positions for a gas engine. If a gas engine is running low RPMs with a closed throttle - the air draw is close to a that of a diesel. If a gas engine is running high RPMs with a closed throttle (thus creating engine vacuum) then it does take in substantially less air then the diesel would.
Seems in your case, all you need to know is the most flow needed so the air cleaner won't restrict flow. That will be basically the same.
I recently went though all this when I was trying to find an air-cleaner assembly to fit my 6.2 diesel motorhome after I installed a Banks turbo. I got reading many air-flow specs for factory installed air filters. Gas or diesel made no difference. Horsepower and max RPMs did.
The air filter for a GM 2.8 will flow more air than the OEM Ford tractor filter ever did. That because the 2.8 can run much higher RPMs.
Not correct CJ
Diesels are 4 stroke also, Exce[t fot the old Detroit Diesels.
Filter area affects restriction to air flow and filter life only.
Thank's for all the feedback.
I felt pretty sure the GM 2.8 filter could handle the diesel's volume since the cubic inches are identical & rpm's will be less than half for the tractor.
I think I'll try scrounging the junkyards for a 2.8 cannister to modify for a trial.
