diesel engine break-in questions
Dozer Guy
I have built many gas engines, but only a few diesel engines. some people have told me to just put a diesel to work,some say take it easy for a few hours and dont work it. I just put a crank kit in my 236 perkins, should I take it easy, or put it to work? And what is the proper way to break-in a complete re-build? Thanks in advance! D.G.
My Dad and a friend of his used to overhaul big truck engines all the time.They would always start it,run until up to working temp,then shut down and let cool completely out overnight,then take'er out and pin her ears back on a load
Like the others have said, start it warm it up then shut it down and retorque the head bolts and check for leaks. Then put it to work but don't lug it down for a few hours. Don't let it idle as a diesel needs to be worked and kept hot so the rings have plenty of oil splashed on them while they are breaking in.
