diesel engine problem
mmidlam
Got a 4 cylinder diesel that sounds more like a 2 cylinder John Deere. Blowing a lot of black smoke. Loosening lines to check cylinder balance gets different results when cold or hot. How come? I will do more checking. Maybe an intake valve not opening? pump was rebuilt not long ago. What would happen if an injector adjustment backed off?
Hello mmidlam,
How about a little more info.2 cycle 4 cycle.
Black smoke is incomplete combustion, which can one of mean many things are not right.Bad injector tip, low compression, valves out of adjustment, bad pump to mention a few.
Guido.
black or grey smoke.. probable causes
incompletely burned fuel.
excessive fuel or irregular fuel distribution
improper grade of fuel.
water outlet temp at 160F min.
If you think it may be a valve, take off the rocker cover and observe the valve operation.
Hello mmidlam,
I would first take a compression test.
While the engine is runing feel the exhaust manifold to determine which cylinder is not firing. If the injector is bad in the cold cylinder, you can swap one that is firing, and see if the enjector is the problem. If the injector does not fire at the dead cylinder,and cold injector fires up in the new location, it would point to the pump. Check the valve action with the cover off, maybe other reasons why the cylinder will not fire. Broken push rod or an hanging valve. Bad cam lobe. Valves out of adjustment.
Guido.
