Eagle Doc
I would like to talk with you about several questions I have about a fuel pump fitting on my tractor. My email is open, I use the classic view.
Info from the Bosch 1964-69 Case listing.
A22634 730
A22635 730C
A22636 800
A22632 803
A22633 830C
Last two have 8.5 MM plungers, first three have 8.0 MM plungers.
Make SURE the rack is not stuck BEFORE starting engine on any pump that has not run awhile.
The rack is not stuck, the drive gear turns normally. Oil ran out of it when I picked it up to look at it. I assume you got the email I sent. If you sent me an email I did not get it, but my email sometimes doesn't work.
Thanks for the reply and I appreciate your helpfulness and the knowledge you share with me and others.
