Welcome to the new forums
YTSupport
Administrator
Staff member
The boards are all up again. Please let us know if there are problems. You can email the support at yesterdaystractors.com or admin at yesterdaystractors.com.
If you have the wrong username or password, you can use the options at the login to reset the password. If you also didn't check if your email address was set correctly, you'll have to contact us for a password reset.
One thing I can't stress enough, everyone is set to use the Threaded View, this is similar in function to Classic View, if you want to use the Chronological View (like Modern View was and all other forums), click on your username and select preferences.
Be sure to read the document on all that at https://www.yesterdaystractors.com/cutover it shows some preferences you might want to change.
Edit: If you find that the time is wrong for you, check your Time Zone in preferences. Click on your username and select preferences.
Im sorry, I really dont mean to be rude, and I think its great YT has moved forward, but this looks like something kids play with. These circles with the intial is just overwhelming. Can anything be changed on our end to change the way it appears?
Thank you and J Hamilton, HFJ, DoubleO7, Jim.ME, Absent Minded Farmer, and Rich's Toys for checking them out in advance and for all the input you all provided. (hope I remembered everyone, it's been crazy)
Glad to help, thanks for asking, It looks good.
Yes, in the document I mentioned above, it has the method of turning that off (username->preferences->hide Avatars). We thought people would hate that, or at least get bored with seeing it so we created an option to hide it.
Your welcome, am honored to have critiqued and evaluated.
When a login attempt fails, is it possible to have post #1 of this thread appear in the failed login window?
Forgot to mention, it speeds up the connection, if you use a slow one like I do, to get rid of those circles. Those graphics people will put in their Avatar will slow you down.
Yes, we are doing something like that soon. We'll discuss it in about a half hour since it was on the list but didn't get done. We are going to have a welcome message at registration so possibly we can also put a help message on failed login. It's a good idea.
Still there in the forums, but not the posts. Maybe enough people will add an avatar so it looks less, bright. Its very odd. Thank again!
I couldn't get rid of the little versions shown on the forum and thread display, only when reading the thread. I'll put that on the list though as that would really streamline viewing the forums. When I was doing that, I was targeting just the thread because the big versions were pretty irritating, and if someone doesn't have an avatar, the Letter displayed in a circle is pretty meaningless. I think the current generation is afraid that any time you have just text, it won't "sell", so unimportant pictures and graphics are stuffed in to make their software desirable. Most YTers obviously don't agree. I tried to hide other stuff but some things were not possible, smilies for example.
Thanks Chris!
Works good! The only thing I noticed is the two vids I posted in the test area, when in the old Classic forum, did not turn up in the new one. No biggie on my end.
Mike
That would be my fault. Until you mentioned it, I didn't even think about it. The import program had to know how to rewrite the statements for the old bbcode (bbcode has changed a lot internally since 2007 ;-)). You might be able to edit the old post and redo the embeds. If the problem is common, in other words there are hundreds or thousands of those out there, I'll have to figure out if I can write a program to redo those posts. It won't be fast though. I might have to contact you on the format you used or maybe, if I know the post number, I can go compare other non-functional ones with how you put it in on the edit. It's still a big job so it will take a couple of weeks.
There's lots of stuff to play with!
What a fancy new place this is!
I'm excited to try things out!
