DIFFERENTIAL HOUSING FORD 555B
pttractorman
I have a cracked diff housing on a 555b hoe, having a hard time finding.If anyone has one or Knows of one with or without guts please contact me. casting # E2NN4024CD . thanx N.C.
Try Wilson Farms near Fredericktown Ohio 43019. Bill Wilson at 740-694-5071. Very nice folks. There are others here in Ohio but I'd have to find their phone numbers. Wilson's have lots of neat stuff and I remember seeing some industrial tractors there also.
Wengers in Myerstown Pa is showing a 555,555a 555c dismantled for parts if the housings are the same www.external_link
tried both of those suggestions and followed up leads from them but nothing found yet. im still looking ,thanx for your effort
That shouldn't really be too hard to find if you stick your head in the right hole.
If you look in PAL at NewHolland online you will see that for certain years the housing crosses to the same one as found on the 4610 ag tractor. That is just the housing... If you think in broader terms I think you'll find that if you slide the whole axle out from under it you can slide a 4610 rear right back in place because that's really all the 555B is anyway... and that might be easier than trying to find the particular housing that you need. I'd suggest to you that most unneeded ports could be blocked off on the tractor housing.
So... if you can broaden your search to a 4600 or 4610 tractor you have a broader gene pool to draw from. I'm quite sure you could find that stuff at Fawcett's. I personally have 2 axle trumpetts and I knwo where there is a wrecked 4610 but the center section is busted... (Petercar's will do that) but it should have good axles. Mabey. I've got to look at it.
Here's Fawcett's...
Rod
Fawcett Tractor
