As Paul Harvey used to say, here's a strange. The power was off for six hours yesterday. I waited two hours before I hooked up the PTO generator to the tractor. It's been a few years since it was used and I'd never ran it with the Oliver 1365 before, but I had just filled it with fuel and it was warmed up, so I used it. Something happened to the tach cable over the winter and I haven't fixed it yet, so the tach wasn't working to know when I was right at PTO speed. The generator is old and the gauge on it doesn't show voltage, just has a red low voltage at the bottom end, green in the middle and then red again at the top. It was jumping around all wonky at any speed, but the lights were bright and the electric stove worked so the wife could make supper.
We have a Bose Acoustic Wave radio under the TV and it has a digital clock. When I started the generator, it came back on to the correct time and wasn't flashing like all the other clocks. After a few minutes, I noticed that it was two minutes ahead of the time on the Direct TV guide. After a while it was four minutes ahead. It was four more hours before the power came back on and by then it was 14 minutes ahead. When the power came back on, I disconnected the generator and turned the main breaker back on. I came in and sat down, the clock on the Bose was still 14 minutes ahead. I reset it to withing about 4 seconds of the Direct TV guide and it's still right there today.
If I had the generator running too fast and putting out too much voltage, would that effect that clock like that? Or maybe it was low voltage? A mystery to me. I didn't bother to set any of the other clocks when the generator was running because it would have been a waste of time, so I don't know if any of the other ones would have acted like that or not.
