Formerly PaMike
I just picked up a NH 408 discbine. Ran it over 4 acers of grass, and it worked great. Went to cut 4 acres of oats for baleage, and I had nothing but problems. The discbine wouldnt cut clean. Left uncut areas. It appeared to be between the last, and second to last disc, on each side. This is also just about inline with the ends of the rolls. Stems would be folded over, like they were run down, but not cut. I tried running fast, slow, opening the roll tension, sharpening the knife. Nothing worked. I left that field and went to a grass field and it cut fine. I did just reshim the rolls, and I got them darn close,but not touching.
Any ideas?
Here are my guesses...
1.Knifes are not the best,could use a new set. Probably not the problem, but didnt help.
2.Oats have thick stems,probably should have dropped the roll pressure further. Possibly causing a "backlog" at the ends of the rolls, and this would fold the uncut stems over before they were cut?
Any ideas?
