Nope, not just you, it is a fact, especially the front mount distributor, the 2nd most misunderstood system on Ford Tractors. The 1st? The 6V/POS GRN System. Guys don't know, don't understand, don't read the manuals and reference the schematics there-in, and when they encounter a non-starting situation, think they must convert to 12V because it is the 6V system fault. Shadetree mechanics are notorious for switching out to 12V and 99.98% of them are wired incorrectly. These are facts -you can look them up, or simply read the daily posts on the boards. The Front Mount Distributer is tuned up and tested off the tractor on your bench -you can't do it when it is on -and before it is remounted on tractor. The engine cam has a female offset slot on the face. The distributor cam weights has a male offset tang and the two must mate up exactly the same. If the unit gets mounted/forced down 180 degrees off, the second power is applied it will try to orientate itself and bust the aluminum base rendering it useless junk. Now, there is nothing wrong with a 12V system, but either way, 6V or 12V, if not done correctly will result in non-starting issues.
SPECS: Point Gap = .015" / Plug Gap = .027" / Firing Order = 1, 2, 4, 3 CCW
FRONT MOUNT TIMING PROCEDURE:
FIRING ORDER, 1,2,4,3 CCW:
FORD FRONT MOUNT DISTRIBUTOR – WHAT HAPPENS WHEN INSTALLED 180° OFF:
ECHLIN used to be one of the few reliable brands but no longer are unless they fixed the problem recently. A year ago I spent a week with my late friend, Farmer Dan Howe, and we went thru a dozen or so front mounts to rebuild, time, and set correctly. What we discovered was that all the *ECHLIN sets were junk –points were off location and couldn’t be gapped right. Lot numbers on the boxes were all over the place and purchased from different suppliers so we don’t know how long they had been like that. What we concluded was there are only three reliable point brands made today. They are: Standard Ignition (Blue Streak); CNH (Case-New Holland); and TISCO. The latter uses the plastic rubbing block but proved reliable, and the other two use the OEM type phenolic rubbing block. ECHLIN also has the phenolic block and that was one reason why they were a good choice.
Part numbers:
1. POINTS:
Standard Ignition (Blue Streak) – FD-6769X
CNH – 87744524
TISCO – ATK6FF
ECHLIN CS-35 (*see note)
2. CAP:
ECHLIN - #FA350 or STANDARD IGNITION - #FD-126
3. CONDENSER:
ECHLIN - #FA-200 or STANDARD IGNITION - #FD-71
4. ROTOR:
ECHLIN - #FA-300 or STANDARD INGNITION - #FD-104, TISCO KIT Includes rotor.
5. GASKET KIT:
SPAREX #S.60308
6. 6V COIL:
IC670
7. BALLAST RESISTOR:
# ICR40
8. SPARK PLUG WIRES –COPPER CORE – nnalert’s
9. SPARK PLUGS:
AUTO-LITE 437 (216) or CHAMPION H12 (512)
10. CAM LUBE:
STANDARD IGNITION - #SL-2
ECHLIN: ML-1
Tim Daley(MI)
