Brad Buchanan
hey folks.
I have a '97 Dodge pickup 2500 with a 360 engine.
I had loaned the truck out and when I got it back the transmission was slipping in first gear.
I pulled the pan and found that the screen was full of aluminum. Also the fluid that they had put in was the wrong type- seemed to be higher viscosity
Changed the fluid (what was in the pan) and new screen. No metal parts in the pan other than some aluminum dust.
It started to just start in high gear and then to hunt a bit but now shifts somewhat better. Slippage is pretty much gone.
Can the trans be damaged by the wrong fluid?
This trans was replaced a year ago with a junkyard unit and I have the original. I am considering trying a rebuild. Can a torque converter be tested easily?
Thanks for any help and comments!
Brad
Brad
