Does The right Stuff go bad??
If you are talking about the expanding foam insulation that comes in an aerosol can the answer is......YEP! At least at my place it is.
Usualy a company that sells it will take it back in our area. Within reason!
A little trick that I do is warm it up a bit also. If you get it to warm, it will blow, also to warm, and it will shrink 75% after it is sprayed on.
I wish I had a nickle for every can I tossed because I kept it on hand for to long.
