(quoted from post at 01:16:09 09/14/10)
(quoted from post at 18:29:32 09/13/10)
(quoted from post at 00:10:15 09/14/10)
So in the 3 years and 150 hrs of operation you never once checked the fluid level in the transmission? If so you would have known it was low and would have done something about it long before now. Did you ever read the owners manual and the recommended service intervals? Small wonder you can't get satisfaction from Deere, they tend not to warranty stupidity.
My suggestion is that you get yourself a $1500 brand X tractor and just plan on replacing it every couple years as they are designed to wear out in that time span and inconveniences like checking fluid levels doesn't really affect that.
I think on the cheaper mowers you can't check the fluid. It's sealed from the factory and no way to check. They are built to last until the warranty runs out, then it's time to get another one.
My Moms JD 332 has a sight glass and checking the trans fluid level takes 1 sec.
True, but as the poster did not specify the model, all we have to go on is his post. Since he said he had JD put a lot of parts in it, I made the conclusion that it was worth repairing and hence a higher quality model. If it was, as you say, one of the cheaper ones, anything over a minor repair would exceed the worrth of the tractor. Additionally, since he cited 150 hrs, I concluded that he had a higher quality tractor as the cheaper ones did not come with hour meters.
If I came off as a little testy, I apologize. But as one who has to deal with service issues, I tend to be a little short with those who find fault with the product when they fail to provide even minimal maintenance.
A few years ago, a female friend asked me if it was normal to have to replace an engine in a 3 yr old car withoout benefit of warranty. She was concerned that she was being taken advantage of because she was a woman. So I agreed to look into it for her.
Long story short, the mechanic told me that in his 40+ years of experience, that was the first time that he ever pulled the plug out of an oilpan and nothing came out.
The blank look when I got when I asked the the young lady if she had ever checked or changed her oil, told me all I needed to know.
I told her to pay whatever the mechanic wanted and to pay attention when he explained how not to repeat this.
e
