Down size a plow
Shawn W
Hello
I got a 5-14 JD F-145H plow. I want to cut it down to a 4 bottom and then maybe on down to 3 bottom if i still cant pull it.
I have been around all different plow my entire life so plowing is not a new thing to me, nor is setting a plow to work. I have had really good luck using these old JD plows, and most people hate them. However i have never cut a plow down. is there anything special i should know before i start on it.
THanks
Shawn
You can do what you want...what are you going to pull it with..??
All-Fuel, Gas or Diesel..?
You should be able to get money in Trade, for a smaller plow..
You won't want to have a 3-14" semi-mounted plow...maybe a four bottom but not 3...
A JD 60 would have all it wants with 3-14" and if it is All-Fuel...it Won't pull 3-14"
A JD 620 will pull 4-14"
On "plow days", I pull 4-16" with my 630..plenty weight and great tires.!
I would rather you sold the 5 bottom to someone who needs one and looked up one the right size for yourself..there are only so many of these old pieces laying around..!!
Ron.
I have seen the manuals for the F145H 's. You should be able to remove the last bottom and move the tail wheel up at least without cutting the main frame. It would be better to find a used rear steering pipe and lift rod off a 4 bottom than cut what you have.
When the snow goes down (not this week) I'll venture out to look at the 4 bottom F145H we have to see what else could be done. Try to find yourself a manual if possible.
I also agree that our F145H actually has been a decent plow.
Shawn, when you reduce a 145 plow you will be removing the fourth bottom on your five bottom plow. Remove the back bottom, then the next bottom forward (the fourth bottom) then reinstall the last bottom with the tail wheel assembly. You will then have to fabricate a rear lift rod and steering rod to make it work. As many plows as there are out there I would look for the right sized plow and keep what you have for parts, or sell it. Hope this helps. Mike
Well guys,
Here the deal.
How many of these plows do i need for parts. I have several 5 bottoms around.
Around here in east central illinois im concidered a bad farmer cause i plow anyway.
and you couldnt give these plows away. Most of them have a broken tail wheel assembly. which is availible from deere for $200 plus, and thats more then i could sell a plow for.
So im taking a couple parts plow to build a 4 or 3 bottom semi mount plow. The rest of the parts that are junk or broke are going for scrap, and i'll keep whats good.
I'm going to pull it with a Farmall M, that has every m&w option there ever was, plus a wide front, plus a tractor supply 3 point. I just got it overhauled and i put 450 block in it and ended up with around 70 horse out of it. I really dont want to pull a plow, so i think this semi mount pull will just be cute, and i can pull it fast down the raod also.
I have seen a few 3 bottom semi mounts around so I cant figure out why this one wont work.
And if it doesnt work I got a 3 bottom #8 IH plow i could use, its restored, or I could pull my uncles oliver 4340 4-14 which is what i was using on the M, But he pulls it now with his MM GTB-D.
I'll try and post some pictures of it next summer when its in the field working.
Here is a picture of a 3 bottom that belongs to a member of the club I belong to. Sorry I didn't get a close up. You would need to take the last bottom off, the 2 in front of it and then put the rear bottom back on. Shorten the steering arms and the lift link. your choice as to cut the excess frame off. Chris
Hey thanks
I found my book, and it shows how to make a 5 bottom a 4 bottom and a 4 bottom a 3 bottom, there is extra frame on a 5 bottom, compared to a 4 bottom. So with out a lot of major problems, 4 bottom is all i can go down to. However i'm going to make it a 4, and if i cant pull it, I'll fabricate some stuff and go on down to a 3 bottom, I plan to get it all done to take to Penfield and Rantoul next year.
Where do you live? The 720 and the Minnie were plowing at the Atkinson showgrounds last fall. I was plowing with this outfit, not mine, just having fun. Chris
Yes, it has yetter coulters. Did a good job, but we were plowing bean stubble. Those old combines don't have choppers on them, so the trash can get bunched up but went right thru it. I wasn't there the day they picked corn and plowed, but should have gotten along OK. Chris
