I wanted to replace the draft control boot. No biggie, right? Hah.
Anyway, I got it out. Getting it apart is another matter. I have a impact screwdriver but the bit isn't big enough to work in this. I have an old screwdriver that fits it really well but I'm not having any luck in a vice with a pipe wrench. I have a propane torch and I heated it up.
I figure my options are welding a nut on the bottom of the plunger and using an impact gun. I could grind this back off I guess. Cutting it in half with a band saw and using a pip wrench to remove the bolt after removing the spring from the cut off plunger, or cutting the old screwdriver I have(It is missing it's old wood handle and stuff anyway) and welding it or grinding it to fit a impact socket and just going to town.
I see I can order a new plunger/bolt for $20 or so.
Am I missing anything here?
