Draft sensor pin stuck in
Houkster
I have a older international 444 and the pin type sensor below and to the left of the top link is pushed all the way in and can not get it to pull back out and my 3 point is stuck up they will bleed down but as soon I start the tractor they raise all the way up
(quoted from post at 05:36:09 06/05/19) Hi, is the draft control lever all the way forward?
he lever is down the flow valve is open I have tried vicegrips and penetrating oil. Shouldn't their be something internal to kick it back out. Thank you guys for your input
(quoted from post at 12:23:24 06/05/19)
I suppose it's possible for the pin (43)to rust to the bore, however, there's a lip "wiper seal" at the outside to keep moisture and debris out, and an O-ring to keep oil in.
It's also possible that the rod and linkage connected to the pin is bent or broken.
There was some issue, I don't remember exactly what, where the mechanism would get bent, IIRC, chain (#56) is involved in trying to prevent that. (Issue may have been if left arms were externally lifted/forced beyond normal travel.)
I have a "424", which used the same lift setup, IIRC you can see the mechanism after removing the 4-bolt cover under the seat.
I took the top plate off everything looks in place I was able to get it to lower by prying on the #32rod I guess it is possible that it is rusted going to try pulling it out before I tear into it
