Drill bit sharpening...
snoop-nc
Got one of those Drill Doctor machines some months ago and finally got around to trying it out today...seems OK as it sure is better than what I can do by hand. Any comments...pro/con on this #350X Drill Doctor?
What a way to kill some time on a dull/dreary afternoon!! Hopefully Boss will call and I can go trucking!!
Rick
I bought one a couple of years ago. I forget what model but it sharpens bits up to 1/2". Now Drill Doctor has a chuck that works on my model that will sharpen up to 3/4" bits, I have one on order.
I'm always rather doubtful about things that come out new and are highly advertised, but the Drill Doctor works very well. Should have bought sooner.
Dusty
i have one also bough mine with 3/4 inch chuck works realy good and winter coming up be time to sharpen bits again only bits i bought last fews years are small one for starter holes so i dont have to sharpen one evey time i need to drill a whole
I have a drill doctor and I love it. You can also get an adapter for sharpeing left handed bits. If it's a drill doctor its gonna work great.
Love mine--it's a bit older model but does a great job up to the 1/2" limit of the machine. Yes, I can sharpen bits by hand, but once you get the hang of chucking them up, the Drill Doctor is both faster and more consistent. Back a while ago, someone on this board printed a line regarding their Drill Doctor that still makes me chuckle: "the only thing I don't like about mine is the noise--it seems to draw people carrying handfuls of dull bits!"
Sorry gentlemen, I hate to be the one to swim against the tide. :twisted: :)
I was given a drill doctor a few years ago as a thank you for mounting a backhoe on the neighbor’s tractor.
With small bits I thought it was very cumbersome to install the bit in drill doctor’s clamp. And the cam motion of the clamp against the grinding wheel was not very smooth. I tuned around and gave it to my brother n law. It is much easier and faster for me to use a bench grinder. Someone here a few years ago took the time to write a blow-by-blow description of how to sharpen a drill bit by hand, I thought I had saved it, but could not find it. I was really impressed with how detailed this person was with the technique of hand sharpening.
Here are some things I’ve saved over the years about hand sharpening drill bits.
I like my drill doctor. I found it hard to use *until* I watched the video. Then the light bulbs went on and it was easy to use.
While I can sharpen bits by hand with a grinder, letting the Dr do it sure is easier. Except for the extremely large and extremely small bits.
I got a Drill Doctor about 6 weeks ago. I like it a lot. I can do the larger drills by hand, but I can't get a good edge on the smaller ones.
I got the 750X, it will vary the relief on the shoulder and put split points on the bit.
The trick to using a Drill Doctor is to not ignore the instructions, watch the video, read the instructions and follow them. It works very nicely.
Wish I'd sprung for one years ago.
Puddles, you sure worked cheap didn't ya?
Couple questions though.
1. I can't tell what they are calling the web but it appears you look at the open space.
2. Do you twist your hands as you put the bit to the grinder? The last bits I sharpened (3/4"), I twisted my hands so the grinder did the whole sloped surface (the lip clearance area behind the cutting edge) and not just the cutting edge at the end. Once I got the knack of twisting my hands, it was easy to sharpen a bit (a big one anyways)
3. It seems like the very tip is not a point but a straight edge. I'm never sure how wide/long this flat point should be. I assume it starts the cut and may be related to the web thickness.
4. Is there anything you can do for the rounded corners or worn margins other than grinding the lips down past the worn area?
Thanks. If you answer these questions, this will be the cheapest you ever worked.
Another question for anyone. I just burnt up a new 2 1/2" hole saw in some hard wood. Any particular tricks to dressing up those teeth with a file? Hate to buy another one.
bc when doing projects for friends and neighbors, all I ask is it doesn’t cost me money! Replace my steel, hardware, and supplies and I’m a happy camper! :lol:
The web is the thick part right at the tip of the drill bit, between the two cutting edges. I’ve worked with guys who turn the drill bit perpendicular to the grinding wheel on the edge of the grinding wheel and grind a point in the web, this way you don’t need as big of a pilot drill.
I sharpen drill bits just like the man in the first picture, I move the bit to the grinding wheel holding the angle I want to cut, soon as the bit makes contact with the wheel I grind until the cutting edge is even all the way across the cutting face, then I slowly move my right hand down all the while pushing on the bit into the grinding wheel with just a slight clockwise rotation. I turn the bit over and do the same thing. I then hold the bit up and look at the cutting edge; I rotate it to make sure both cutting edges are the same length, and the same angle. If not happy with the results back to the grinding wheel. I never let the bit even get warm much less hot! :wink:
supergrumpy you’re correct.
If I remember correctly I through that vice in the scrap pile, I skinned one too many knuckles because that vice would not hold small objects. :x
Dusty,
where did you order that 3/4" chuck? I don"t recall the model # of my drill doctor...but it only goes to 1/2"......I"d buy a 3/4" chuck if I can find one.
Thanks.
Those early Drill Doctors from years ago as you say were defective.The drill bit holder fit way too tight in the hole for grinding the bit.
Drill Doctor blamed it on the plastics manufacturer who made that part for them.
I sent mine back and they sent me a new model.
The new model the chuck turns freely in.
A great company and a great tool.
Mark
I work at a machine shop that happens to have one of the best darex sharpeners money can buy. It has attatchments that can do countersinks, as well as tiny drills all the way to large drills, I think bigger than 1".
I'm hooked on that, and one of these days I need to bring in all of Dad's bits to give them new life.
Donovan from Wisconsin
Ole Shovel,
Just how many home shop folks can afford to invest in a professional drill sharpening machine? I don't think it has anything to do with being 'too cheap' but rather not making a major investment for a tool that actually gets minor use.
In a machine shop, a Darex might be a sound investment......and most shops nowadays outsource all tool sharpening...obviously because it is more cost effective.
A drill doctor is a home shop tool and I think everybody who buys them, recognizes that fact. And too, the vast majority of folks doing their own work, don't have professional training. Most of us know somebody who is a machinist that can grind bits by hand and make it look a machine done job.....I know a couple men like that. One retired as a journeyman machinist after 40 odd years. But for myself, a $79 drill doctor does the trick. For that kind of money I can neither buy the experience or make a down payment on a Darex.
Now that my eyes are going I find it more difficult to sharpen drills on the grinder. I was taught how to, years ago by an old machinist who also did blacksmith work in the back of his shop.
Makes me think that perhaps it's time to look into one of these types of gagits.
John
General tool co makes a good drill sharpener you can use with your grinder.Been using one since 1973.AD MC burney co sold one for 3 bucks.The General has some import copies so buy the original.May cost 30 bucks now.
Just posted so bone heads like YOU would know !!! What does it matter anyway something tells you know it all but probably couldn"t operate anything. I was just saying the drill doctor is nothing but cheapy homeowner version of the professional sharpener and anyone that took time to look would know that but bet you just went blowing off without even taking a look. Probably is bunch of those Darex around used in good condition if could find one at one those shut down factories unless they shipped all those to china too.
We have those made by General too Sears use to also sell them with Craftsman name on them years ago where we got one at. They also sold a finer grit special stone to use with it so we have it mounted permanently on another grinder. Yep $34.99 and Grainger & Drill Spot shows $36.40 for them now.
http://cgi.ebay.com/General-Tools-825-Drill-Bit-Sharpener-Attachment-NEW_W0QQitemZ200360948453QQcmdZViewItem
General 825 Drill Sharpener
I disagree with using pilot holes. Doing this puts a large load on the corners of a drill.This is why drills often have corners broken off.Using 2 nuts as a gauge works but a drill gauge works better.Big drills take power to run.Ive watched big 2 inch drills turning very slow cut out a 1 piece chip with no breakage.Most drills are run too fast,burning the cutting edge.
