Drive Shaft
How do I figure out the length for a shaft from a 841D to bush hog?
What is average cost?
Does anyone have one for sale?
What color should it be?
Doug
color is usually yellow plastic .. ie the shield.
as for length. measure from halfway down the pto stuf to half way down the input shaft on the mower.. .. make that measurement all the way down, lift level so shaft would be level, andt all the way up.
that will give you minimum and max numbers. then allow for a *minimum* of 6" overlap when it's at it's 'max' extended length.. ie.. up and down.. as straight out level will liekly be the shortest it gets..
soundguy
