DT466 OIL PUMP
DMont
Please, ( actual users ). The DT466 oil pump is a geroter style that started as a narrow 5/8 width gear. The gear used by the farm equip. division now is 1 inch. The oil pump is mounted on the frnt of the crank and is driven at crank speed. Has anyone used the larger 1.240 width as used by the truck division and if so what front case and oil pick up tube were used?
There are 2 that i pull with that run on gas at high rpm. They are externally oiled the pump is mounted where the injection pump was.
I don't have plans to compete with this tractor, just wanted to use the larger oil pump. I could use it with the truck frnt case, but this would create the need for building engine mounts. Thanks for your reply.
