dtlx 71 carbs
Anonymous-0
can someone give me the drill size to clean the rust out of the ports .would prefer the answere in fractional increments.
Soak that thing in the works toilet bowl cleaner. Keep checking on it , but 1/2 hr. should do.
I used to sandblast them with light pressure and worn out sand, but I tried the works on a Ford carb. the other day and it Worked ! I wasn't about to experiment on my Jd carbs. LOL !
heres the two drills Roberts Carb lists
Number 40 (6-inch) Bit for Idle Passage 6" long #40 drill bit for cleaning carburetor passages $4.97
Number 53 (6-inch) Bit for Idle Passage 6" long #53 drill bit to clean carburetor passages $11.92
