dumb question
Anonymous-0
I would like to replace the front wheel bolts in a few tractors but I cannot seem to find any through a wholesaler because I do not know the name of them. I know they are 9/16x18 1 3/32 long but what are they called. I need about 48 of them.
Most front wheel bolts for tractors ARE NOT a standard hardware item. You need to go the the tractor dealer to get the correct bolts.
Kent
You might get a more useful reply if you specified the make and model of tractor.
I know that the front lug bolts for an hundred series Ford is a factory-only item, which is to say they are available but outrageously expensive.
They are lug bolts, hex head, typically tapered. Any tractor dealer should be able to have them or get them for you. At least you know what size you need- big advantage for the parts guy.
They're called lug bolts, and Dorman has a complete supply shown in their lug nut/stud/bolt catelogue. NAPA and others carries their products.
