dumb question
Soys and canvas feed aren't the greatest combination, but if only a few acres you will get thru it. At least one aftermarket supplier makes new canvas. Not cheap but you can get it.
Warren, I got more rubber type of canvas and cut beans fine, even cut milo with no problems. They are a little heavier that straight canvas. Do have the info, but will look for the company who I bought from.
my 12a works great in soybeans im not sure what the other guy is referring to? canvas is very spendy but still available. 5-600 i think i was quoted.mine has the straight cut head.
Dry soys have a tendency to slip down the rotating canvas until they gather in a bunch and then feed. Uneven feeding is the result. Go slow enough and/or have enough green material (weeds) it isn't a problem. But green material makes threshing more difficult. Short beans are worse, green stem beans are likely better. Soy's are also harder (wear) on a canvas. The new rubberized canvas help feeding and wear. An auger and chain feed is just better, although the real big heads use a draper and chain feed.
