early 8N clutch
Anonymous-0
My clutch will not disengage. Good pressure,
correct adjustment,I have heard about a stuck clutch
but I do not know what that means. If that is the trouble what is the easiest way to fix it?
regards Clay
Try posting on the "N"-specific Board, or even better, do a quick search of the archives there. Here's one of the first threads that will come up...
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=nboard&th=707090
Untitled URL Link
Common problem with them. Things you can try but be very extra careful doing so. Block the pedal down for a few days might do it. Start it in gear and drive it till it pops free. Pull the starter off and spray the clutch area with brake cleaner all of which may or may not work
