early styled BW
Looking in the 1942 Wholesale price list from John Deere Plow Company of Lansing, Michigan, the number 154 Model B tractor is listed as available on steel with 4 speed and same number 154 on Rubber with 6 speed. Curiously enough there is no mention of a wide front available for the B or the A! Even in the "extras" list there is no wide front mentioned. It must be just the Lansing Branch house, because there were wide front in the sales brochures of the time. I hope someone can help, I don't have the answer to your question.
You will have to send the serial # in to 2 cylinder for a styled BW! To get the info on it! What is the serial #??
Bob, the reason it does not list a wide front "option" for the A or B is because there was no option. These tractors are knows as AW and BW (or AWH and BWH) tractors with a different order code. Look again at the price list and odds are you will find this information. Mike
Chris, he was asking for the build code, a model number designation the factory used. Instead of calling it a BW they went by something like 155. Serial number research will get a CJ or code for a custom job for a specific tractor, if any.
I agree with you Mike. In the unstyled registry the BW's etc were their own model. They were not B's with optional front ends. Unless they changed when they styled the tractors I would say the same applied. You could however buy a wide front end for your tractor that could be put on by the owner or the John Deere dealer. I have a 38 B with wide front but it's not a BW according to the registry, it was put on after it left the factory. JimO
If I had found my copy of the 1941 John Deere Plow Co. price list from The Baltimore Branch first, all the questions about whether I could read would have been unnecessary. I was just trying to answer the question. Now that I have found the above mentioned list I can tell you the early styled BW was referred to as the no. 157 [same as 154 except with adjustable front axle]. Prices for this model were $757.50 (4 speed on steel) to as high as $967.75 (5.50x16-4P front 10-38-4P Heavy Cast rear).
