(quoted from post at 22:07:05 02/23/09) I am thinking about putting a electric fan on my radiator to get my a little more HP to the tires. Has anyone done this? Is there a specific fan from a certain model of car that fits perfect.
(quoted from post at 22:14:30 02/23/09)(quoted from post at 22:07:05 02/23/09) I am thinking about putting a electric fan on my radiator to get my a little more HP to the tires. Has anyone done this? Is there a specific fan from a certain model of car that fits perfect.
What you smokin'?!?!?!?!!?
(quoted from post at 22:27:03 02/23/09) The Fan eats up power. If you take it off that HP can make it the back tires.
EricR: Fan uses electric power, it has electric to mechanical conversion loss.(quoted from post at 22:31:47 02/23/09) 8N 12V
You may be to old. I have a k&N air filter on it and has noticably more power and the oil looks cleaner. I also put electronic ingniton on it and that gave the engine a boost as well. Some people like stock, I am not one of those people.
(quoted from post at 22:37:59 02/23/09) even if I can get .5 HP more out of the engine the way the 8N is geared that can make a hell of a increase at the back tires. Mr Ford put a very aggresive fan on that tractor.
(quoted from post at 22:46:42 02/23/09) When I pull my 2 bottom plow in second gear if I go a little deep or hit some heavy soil it wants to slow the tractor down to the point it wants to stall. In first gear I just go and keep my depth correct. It would be nice to do that in second gear
(quoted from post at 22:56:15 02/23/09) Did you ever think that the fan on your tractor is too aggresive??? Also if you hook it up to a thermostat it will only run when it is needed. Gotta push the edge gotta try new things. I have an engineering degree and one thing that it has taught me is that the numbers do not always jive. Quit smokin the old stuff one hit of the new stuff is all you need.
(quoted from post at 23:01:09 02/23/09) the point of all of this is that I think and it is my personal opinion that the fan is pushing to much air so I could either put a less of an agressive fan on or put an electric fan on. Maybe it wont keep the engine cool and then I will go back to the old fan. I have got to try. What would this world be if no one ever decided to say "what would happen if we did this"
(quoted from post at 23:12:26 02/23/09) Then why do we not still drive model T's. They get us from on point to another. The K&N air filter breathed new life into my 8N.
(quoted from post at 23:43:18 02/23/09) If an electric fan didn't squeeze more hp out of a gallon of fuel and put more hp to the ground they wouldn't be putting them in all the Toyotas etc.
I see nothing wrong with trying to modernize these tractors or get more hp out of them. Think about those dual exhaust manifolds you can buy.
How about the live hydraulic kits they sell or the Zane thang.
It wasn't looks that got these tractors to be the icons they are. It was functionality, efficiancy, practicality, etc.
I hear ol Henry himself wasn't real sentimental.
Makes me think He'd have more of an interest in the improvements folks have made to an N rather than the originality of one.
Transverse engine is why Toyotas use them. Dual exhaust on a N is for looks and the psychological boost in HP it provided for the mind of the owner.(quoted from post at 23:43:18 02/23/09) If an electric fan didn't squeeze more hp out of a gallon of fuel and put more hp to the ground they wouldn't be putting them in all the Toyotas etc.
No opinion on whether an electric fan is pro or con but why would you [i:2dff0e7f28]need[/i:2dff0e7f28] to pull a plow in 3rd gear?I will be able to pull a two bottom plow in third gear.
And the engnr Eric appears to believe he not only has a lossless gear train, but a gear train that actually increases HP.(quoted from post at 05:58:02 02/24/09) You may have a degree but your spelling and common sense is lacking.If you think expensive ignitions make more HP you have some screws loose.Plowing in 3rd gear will break up parts and plant the acorn nut in your forehead when the plow hooks on something solid.
(quoted from post at 14:23:30 02/24/09) The only time you put more power to the ground is without the fan running!
o, that brings us to, "why electric, where we must make a double energy conversion from mechanical to electric & then back to mechanical?" Large truck engines use clutched fans to totally disengage the fan (non-electrically).(quoted from post at 14:57:59 02/24/09)(quoted from post at 14:23:30 02/24/09) The only time you put more power to the ground is without the fan running!
I was going to stay out of this rather frivilous debate but Jerry hit the nail on the head. Automotive electric fans don't run continuously like a belt driven one does (yeah I know about fan clutches). That's [b:aa291da158]one[/b:aa291da158] of the reasons they are widely used on modern cars - transverse engines or not - they help squeeze a teensy-tiny bit more efficiency out.
TOH
http://www.solarcarandtractor.com/8N_Ford_Tractor.html(quoted from post at 17:04:04 02/24/09) I think the electric fan is a great idea, in fact let's take it to the next level.
Replace the engine with a large electric motor. Fab up some brackets to drive the generator and bingo !!
Now we have a tractor that doesn't even need gasoline. The generator charges the battery, which in turn runs the motor, which runs the generator and recharges the battery.
Perpetual motion has arrived !!
(quoted from post at 03:13:19 02/25/09) It was an aluminum head. Supposed to give you a couple more horses due to an improved combustion chamber. They get big money for them. The last one I saw the seller was asking $1000 for. I don't know if he sold it.
6.1 vs 6.7 CR(quoted from post at 22:55:34 02/24/09) [i:8968491c4d]8N head is a cast iron knock off of a Sherman luminum head,,, the 8n B'n iron would B a better head[/i:8968491c4d]
Didn't know that. Did wonder how they gained the couple extra HP on an 8N.
Cept you can't polish cast iron like you can that aluminum...
HOBO, as usual, dead nuts right! But looks purddy & looks like owner got some $........or had some before head buy. :lol: :lol:(quoted from post at 23:15:50 02/24/09)
Shinny don't make HP :lol:
(quoted from post at 22:36:59 02/24/09)
this is a pix of a quick riggernig on a jeep I did
