Anonymous-0
Last couple of days we have had half the power go out in our house with no breakers tripped. The power eventually comes back on, apparently when the pump-trol switch on the pressure tank for the well flips on.
Today I noticed some "sizzle" and "crackle" noises in the main breaker box. So I tested for a hot panel, shut the main breaker off, and took a look under the panel front cover. I found that some significant arcing has been going on at the point that one of the line-in wires is going into the main breaker, which is a SquareD 2-pole 240V/150A main. By the smoke marks around the terminal on the breaker and the panel area behind it, it looks like the arc is occurring between the line-in terminal and the panel itself, over about a 1in gap.
I tested all the load circuits for shorts and didn't find any, so I know the problem is at the panel or before that point. I suspect the main breaker since that is where the arcing is occurring. Any other ideas? Or should I just go ahead and try a new main breaker?
