I have a slight dilemma with where to put the battery wire from the alternator on my 300RN. I decided to use a voltmeter instead of an amp. gauge as suggested on this forum. I have the ignition/start switch power coming off the hot side of the starter solenoid. All other things gets its power when ignition/start is turned to the on position. Now I need to know where to put the battery wire from the alternator. Can I attach it to the hot side of the starter solenoid so it can charge the battery from there? The previous owner had everything hooked to the amp. gauge, including the ignition/start switch. The + side of the voltage gauge is too small to attach all those wires to. That's why I had to change things around.
