The other day at work an inexperienced electrician (he has only been doing electrical work for about a year) arrived to wire a new machine for our Woodshop. The shop has a 220v single phase outlet, 50 amp circuit, which is setup to plug a door machine into when needed. That's basically a shaper with 2 heads, which can cut raised panels and stile or rails. Big 5hp motor which draws about 40 amps. The new machine is a muti spindle drilling machine which does hole for european hinges or shelves. That machine draws only about 10 amps.
Now here's the question, the electrician said you could not run the drill on the same circuit as was used to run the door machine. Am I nuts but I don't see an issue running the drill on a higher amp circuit. Just because it can provide more amps it's only going to provide what it draws. Or am I wrong? Just thought it was an interesting question. The electrician wanted to add a lower amp circuit just for the drill.
Sorry for the long post but I wanted to try and explain what I was asking.
