Anonymous-0
Here is a hint for anyone doing electrical work on a tractor or any equipment for that matter.
I have been working on changing the alternater over due to the fact that I could not get the external regulator unit to produce and charge the battery to an internal regulator style. I completed all the wiring and tested it out with no success. I checked to make sure the alternater was good by putting it on another tractor. It was good, also new.
Here is the kicker! I was using a volt meter to replace the old amp meter in the system. A meter is a meter right, wrong!. A volt meter works from positive to negative. An amp meter checks electricity going through one wire. Point being made, don't try to close the loop with something you can't close the loop with.
Well, at least you didn't make the swap the other way and "let all the smoke out" of an ammeter!
