Electrolysis ?
I can"t get a old charger with out one of them auto Shutoffs.
I found a Electric fence charger that plugs into the wall. Woud I be able to use that for the Electrolysis It has a + and - at 120volt, I woud still be getting the Ground to the part and the + to the rods.
Its just an idea.
Wont work.Most chargers put out 10000 volts.Electrolysis generates flammable hydrogen gas.You may get some good shocks with your idea.
It"s got to be DC voltage to work, not AC. And it will work best if the voltage is in the 10 to 30 volt range. I don"t know about auto shutoff . .. what does that do, shutoff when the battery is charged? I guess that means the charger can tell when the current stops flowing. That"s what happens when the battery is charged. In electrolysis, the current doesn"t stop flowing, until the rods get contaminated, and have to be cleaned. I think it would work.
10,000 volts? . . .huh? It"s not the flammable gas you have to watch out for, it"s that sweet smelling stuff . . .
to my knowledge you should us a 12 v battery and then hook the charger to the batt. the batt. gives true dc, and the charger is keeping the voltage up. 4 to 10 amp should do the job. all depends on how big your parts are. bigger parts need more amps.
I use my trickler charger. Don't need an expensive charger with a timer. If you want a timer I would go to the local hardware store and just buy a timer to plug your battery charger into. If you do use a timer how would you know how long to set it for? You have to keep it on until the part stops bubbling/boiling/foaming. I've had parts hooked up for almost two days and over night many times. It sure does a good job. I bought a stainless bowl at Walmart for $7.00 and put my small parts in it. It works great when the container/anode surrounds the part you are trying to clean. A large coffee can works but it will only last about 4 days until it gets eaten thru.
Fence chargers generate pulses of high voltage with low current. Electrolysis requires steady current at low voltage.
Probably the easiest option is to go to Radio Shack and get a 12 volt DC power supply. If you get an adjustable one, you can control the current. If you don't mind taking a long time, a DC wall wart might also work.
Keith
I use an automatic charger for electrolysis and set it at 10 amps and leave it on for days at a time. It is a sears charger.The automatic shutoff usually works when the battery is fully charged. In this case the battery never gains so the charger just keeps plugging along. Henry
John B., I'd be careful about using stainless steel for an anode, it will release hex chrome, which does nasty stuff to you over time.
