bisonfarmer
I have a 960 and would like to put in electronic ignition. Would anyone know if I need to change the coil?
(quoted from post at 18:59:35 02/10/14) When you made your conversion did you have to make any modifications for everything to fit?
If that's all you use the tractor why spend over a $100.00 to convert that money would buy points & condensers for ever+ a new battery when needed?(quoted from post at 20:37:13 02/10/14) Thanks for the feedback. After reading everyone's comments and doing some other research I still think that with the small amount of use with this tractor putting in electronic ignition with the 6 volt system would be the simplest and still produce good results. If I lived on the farm where this tractor is and used it several times a week I would most likely put in the 12 volt system. If I use this tractor 3 times a month during late spring thru the summer I am doing good.
No ballast resister, using coil that needs no external.(quoted from post at 19:31:26 02/10/14) If you are running a coil that does not need the ballast resister then you are good to go.
If you have a coil that needs the resistor then you just add another wire from the switch (or in front the the resister) and give the module full voltage.
EZ
You do know that the Pertonix ignition system is not a true electronic system in the sense that auto's use, it's not a CDI but rather a points eliminator system and one of the draw backs to the 6 volt positive ground system is if someone was to jump start the engine and accidentally connect the battery as a negative ground setup chances or the Pertonic module will be fried instantly.(quoted from post at 06:55:54 02/11/14) Good point (excuse the pun). I just thought that electronic ignition would outlast the need of changing points more than once and help the tractor run better.
