emergeny shut off switch
Anonymous-0
I am looking for a Murphy switch for a 4430 tractor. This is the emergency shut off switch that has a temp and oil pressure gauge in it. If either go out of the parameter it will shut off the tractor. Usually shutting off the fuel. Some people also call it a tattletale switch. Does anyone know if they can be bought new and who carries them? Thanks.
You have a mechanical pull cable to shut down the engine.You will only be able to use the light and alarm,it won't shut the tractor down unless you put an inline fuel solenoid. Even then the tractor will still run until the filters and injection pump run out of fuel.
Sure, I had to do a little browsing but this is what I have generally seen in the past. They make them for the newer tractors with electronic control units as well. I'm sure the price is a lot more for them though. Go to www.fwmurphy.com/wd100/
