engine exchange
Anonymous-0
i saw it on YT before but didnt understand, it was said that you cannot put a 4 cylinder motor off a IHC 210 sp windrower in a small tractor because it didnt have a hole in the end of crankshalf for the transmission shalf to fit, i would like to do this , is that because hole in flywheel that is bolted not deep enough, Thanks to everyone that can enlighten me on this. LES.
The transmission shafts goes into a bearing in the endof the crank, so if it is not drillde for this bearing/bushing it will not work.
I met a guy who drilled a hole for the pilot bearing ands it worked for him. Just used a hand drill and said it wasnt that hard to do.
