FayeWedell-HT
I have a Yanmar 330 tractor. Before using tractor w/ brush hog this week, I blew out the radiator grill and air filter...checked and added 15-40 W oil and checked antifreeze. Coolant was at full mark on overflow bottle. I also put in a new fuel filter. Now, the problem: About 40 minutes into mowing (grass not too thick), engine started losing power and suddenly lost all power before I could shut down engine. No indicator light came on...antifreeze was boiling out of overflow bottle. I let it cool off for 2-3 hours....radiator showed full with overflow bottle at a low level. I tried to start again...it turned over, but would not start...acted as if battery was low. The next day, I tried jump starting it w/ cables off truck and after a few tries, it started. I drove it from pasture to the shop (10 minutes) and it died again. I could smell burning oil with more blow-by underneath than usual. NOTE: This tractor uses a lot of oil and emits white smoke. Engine does not knock and has good power compression, but I do average using almost a quart of oil each time I use tractor with a load. Not sure what to do next to repair...any suggestions?
Ideas appreciated, Scott
