So this is a disappointing post to make but here goes...A year and a half ago I bought a Yanmar 2210 with a FEL that needed some work. I didn't know it when I bought it but it ended up needing a complete engine rebuild due to low compression and some worn internal parts, included the crankshaft. I got a local diesel mechanic to do it as a side job. Over a year later I got my tractor back and paid too much money. Hindsight is 20/20. At the time I knew nothing about diesel engines. Now I know slightly more and learning everyday.
After about 1 month of use, not even a tank of diesel burned, one evening it blew a puff of white smoke and started clanking really loudly. I limped back to the shed, it was lacking any power, and parked it and contacted the mechanic that rebuilt it. The mechanic won't call me back. I got tired of waiting, it's been over a month, and started troubleshooting.
I cranked it and it seemed to run fine, no weird noises. I thought maybe I got lucky and it was water in the fuel. I used it a couple of hours yesterday and it would lose horsepower on any incline. I also noticed very thin oil spewing from behind the fuel pump shims. I pulled the FIP off and noticed a rod just sitting on the camshaft. This rod moves around freely but I cannot pull it from the hole the FIP fits in. This rod is the diameter of a pencil. After some research I believe this is a push rod. I also noticed, when I pulled the FIP off the tractor, that there was a single washer on one of the studs the FIP fits on. This washer was behind the shims and only on one of the four studs. This helped explain how the oil was spewing from behind one corner of the FIP.
At this point it actually cranks and idles just fine. Not strange noises or smoke. Once you begin using the tracotr the loss of HP on inclines and while cutting grass, and the spewing of the thin oil from behind the shims on the FIP are the main issues I've noticed. The hydraulics seem to work fine.
My guess here is that the washer left behind the FIP shims threw off the timing, though I didn't notice any timing issues before this event occurred, and damaged the push rod disconnecting it completely. Is that probable, or even possible? Would this issue also lead to the diesel fuel mixing in my oil? What are your thoughts ymowners?
