Engine removal
I need to remove the engine from my Farmall A and I was wondering will the engine pull away from the bell housing without removing any bolts from the clutch. Will the flywheel also just pull away when removing the engine. To put it simply will the engine just pull away from the bell housing without remving any bolts other than the bellhouing bolts the attach the engine to the bell housing?
Yes the engine will pull away from the bell housing with the flywheel cluth and pressure plate attached all in one piece.
