engine swap
caterpillar guy
I posted this on the farmall board. I wanted to know if I could put 414 out of a 1086 into an 856 where a 407 was. I am triying to find out if it would be a straight bolt up or, if it will need some changes. Found an 856 with a bad engine and have a 1086 with problems back of the clutch. Just thought could make one run out of the two.
The ih 15b series dozer used the ih 407 engne then the ih td 15c came out with the ih 466 (same series as the 414 engine) Lots of people tried to repower and replace the old wore out 407s with 466. The engine would bolt up then you would spend 2 weeks trying to make things like air intake, exaust, radiator hoses ect. work. The real big diffrence is the throtle or fuel pump is on the other side of the engine..Anything can be made work but you might want to re think the swap.Lots of work.And in most case never really right.
