RCP
- Location
- Grove City Pa
I am in the process of tearing down a Cummins 5.9 diesel for a rebuild, I did not hear the engine run before I bought it and did not get much history on the engine. When I pulled the oil pan, the flange on the thrust bearing was laying in the oil pan. Upon further disassembly, I found no damage to the block or the crankshaft, but I did find the remainder of the thrust bearing in good shape except for the missing flange. This engine was mated to an automatic transmission. I also found some bent pushrods and I think there was water leaking into one of the cylinders.
Has anyone else seen this type of failure?
Any idea what would cause the failure?
What should I do to avoid a repeat failure?
Rich
Rich
