Greyhound101
A few months ago, I posted that my temp and fuel gauges were 'dancing' when operating the tractor at anything above an idle. I've checked my ground (even ran a seperate wire back to the battery to make sure I had a good ground) and the 12v+. My multimeter shows a voltage of between 14.5v-15v (depending on RPM)at the wiring cluster. I've measured the ground contacts on the back of the cluster and there is little to no resistance so I should have a good ground at both gauge points. In my I&T shop manual, it shows a voltage stabilizer in the circuit behind the cluster. I called the local dealer and they told me that the 4610 has never had a voltage stabilizer? What (if a non-stable voltage isn't) could be the problem? If the stabilizer wasn't $71.54, I'd go ahead and buy one and install it just to eliminate that variable. I'm stumped.
