Erratic voltage?
A Deere 49
I have bought a 1949 JD A. It has been converted to 12V negative ground and still has the generator. The gen. was getting hot and not charging so I took it to a auto electric shop and had it fixed with a new regulator and arma ture. Even with the gen. unhooked and removed from tractor I am getting erratic voltage on my digital meter (12v-17v constantly changing), even laying the meter on the tractor seems to pickup voltage. Is the voltage coming from the delco dist. or the coil? There is no resistor between the ing. switch and the coil. Thanks
Many digital meters go ape in the presence of noise like that from an ignition system or a radio transmitter. Try an analog meter.
Gerald J.
If I understand you, you are running straight off the battery with NO generator correct?? If thats the case (or even if not but less so) when the points are closed the battery voltage may drop ever so slightly cuz theres a 4 amp current discharge and then when the points open (albeit a short time) that potential slight voltage drop could disappear. The thing is some of those digital meters dont respond / behave well as compared to slower responding damping analog needle movement meters which tend to smooth n dampen n steady out any short term fluctuation cycles which that digital meter may be trying to read and report. AS fas as radiation and magnetically induced voltages (which a sensitive digital meter might see) each time that coil builds then collapses its magnetic field theres got to be all sorts of stray electromagnetic field activity, maybe your meter is responding to such, darned if I know....
Id stick a meter like mine, a good old reliable Simpson 260 analog etc n Ima thinkin you will see a steady 12.6 volts or so with no genny and maybe a steady 13 to 14 with a good charging system and battery . If an analog meter shows bad voltage fluctuations I suspect a poor ground or a poor connection or a Voltage Regulator problem or else a genny problem...
John T
